Sup guys, my car has been overheating.. it starts.. takes a lil to heat up and the temp shoots all the way past hot.it started doing this after I took out my cluster and changed out some bulbs..(b4 that my temp gauge would stay on cold while on the freeway n go up when stopped as stated in 1 of my previous threads) All the plugs looked fine b4 I put everything back together..i changed the temp gauge sender and the thermostat and that didnt work. Any1 know where I should go from here? Would bleeding the coolant system solve the over heating? Thanx in advance,
over heating problem
http://techauto.awardspace.com/overheating.html
Good, easy to follow!
and youtube bleeding coolant system Honda Accord
Haven't been on here n a bit but its still doing the same thing after bleeding the system. .. Shooting up past hot but what im wondering is can it even over heat from a cold start in literally like less than a min? And then I turn it off and turn it back to on position and it shoots right back up before I even start it? Im thinking its my cluster thats bad but not sure,
I believe your thermostat failed in closed position. Change it and retest. It is easy to change and inexpensive.Last edited by JDMDriver; 06-23-2014, 09:55 AM.Rides:
Accord
92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
96-AUDM-2.2 VTiS- Heather Mist
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" Motegi Edition - Silver
95-JDM-SiR "Transtop" Daytona Edition - Silver
92-JDM-SiR "Transtop" - Black
Prelude
91-JDM-Si-4ws "Si States" - Phoenix Red
91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
Originally posted by cb9_marty View PostNo it doesnt move when its unplugged, could the cluster have gone bad cuz I didn't disconnect the battery when I removed it or is that okay,
Originally posted by cb9_marty View PostHaven't been on here n a bit but its still doing the same thing after bleeding the system. .. Shooting up past hot but what im wondering is can it even over heat from a cold start in literally like less than a min? And then I turn it off and turn it back to on position and it shoots right back up before I even start it? Im thinking its my cluster thats bad but not sure,
Originally posted by sonikaccord View PostThis sounds like a bad sensor to me. Less than a min? Your car isn't even warm yet. When you disconnect the red wire, nothing happened so that's good. Does your radiator fan kick on?
