Anyone here know how much power the stock transmission will hold? I want to convert to a manual but currently have the stock auto in it. Is it worth anything above 300hp? I want to make at least 400-450 with my car and already know the automatic isn't worth it. but for now..??..??.. I'm planning on going turbo. anyone have suggestions on specific tranny codes for a manual swap? I don't mind opening the tranny and putting a good lsd in but I would like close ratios.
I will probably cryo the gears and would like the largest diameter mainshaft possible. Does Honda make a six speed that will bolt to an f22a6?
for the manual conversion I already know.. slave cylinder, clutch resiviour, pedal cluster clutch line (probably a nice braided one) , flywheel, clutch and pressure plate, throwout bearing, axles, and the right section of my instrument cluster (minus the PRD12 part). no transmission control computer and of course the shifter and cables. am also guessing the transmission mount is different.
Any suggestions on tranny codes? ratios? or beefy stock axles? Thank you all
