In Need for help On my Head Swap
    Okay Long Story Short
    I jumped Timing stretched belt
    Bent 4th cylinder valves
    Broke 1 valve clean break that rattled between the head & Piston
    Messed up (ONLY) the head & Piston in 4th cylinder walls were in No way damaged at all only piston & head were in 4th cylinder
    I did have a shop replace all my pistons/rods as wel
    So city I'm living in for Junkyard parts have NO Stock PT3 head or any F22a_ heads
    But I did happen to find a F22B2 head SOHC looks very similar to the PT3 head
    So my Big Question is Will this head work fine?
    Is there anything else I need for this to work (Short time USE ONLY till I get ahold of a stock PT3 head)
    But I did happen to purchase it since it was only $28
    Bought new Valves Installed them
    Swapped over my PT3 heads guts & Camshaft to the F22B2 head
    Bolted up fine
    Swapped out my Headers for a pair of unknown brands but dude told me they were Apexi??? Not sure so we'll just call em EBAY headers haha
    Thanks for Viewing and Helping You guys have a Great Night/Morning.
    Pic of the old head
    [IMG][/IMG]
    If it is for short time use you are going to be looking to spend around the same as it would cost to have a PT3 head shipped from out of town.
    You need the complete intake manifold and throttle body. Thermostat housing and coolant bypass tube. If I'm not mistaken I think you have to the lower half of the F22A bypass tube and the upper half of the F22B1/2 tube and weld them together. There may be another bypass tube that works I'm not 100%. H23 or DOHC F22B one might work????
    I remember seeing a build thread were someone took and F22B1 and put it on the F22A block. The F22B1 uses the same setup of components as the F22B2. So if you can find that thread it may clear it up some for you.
    Just remember that for the non VTEC F22b2 head You do not have to remove the oil control orifice like you do for the VTEC head swaps.
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      I need help too with heads but could not find a thread
      Ok this was the best place I could find to ask this question... Hope someone can help...I jumped time and so put a new timing and balancer belts on...still won't start, a friend told me it needed a new head...have not pulled it yet...found a running motor for $250 and a $250 remanufactured head...which should I get...if I buy just the head I drop it on and I'm done...if I buy the engine I get a used head plus the engine to build up later...which should I do?
        Please don't hijack someone else's thread. Start your own.
          Sorry....my account won't let me start new thread
          Sorry....my account won't let me start new thread...don't know why?....any help who be great
            Are you trying to post it outside of the beginners forum? While your post count is low you only have access to beginners forums but they still contain a wealth of information .
            " Insert funny quote here "
              Read the rules. Everything is explained there. You may start new threads in the Beginner Forums only.
                heck if it was me i would get the other engine so you could have a spare to build up
                  The OP hasn't bothered to log on in nearly 3 weeks. This thread would've disappeared had SOMEBODY not dredged it up from the bottom of the page.
