3rd gear not there?
    3rd gear not there?
    Ok i was driving my girlfriends 93 ex coupe today after doing the breaks on it and i went to take of from the next stop lightand when i went to 3rd gear it felt like it went in but it did nothing. No grind or anything just like it was in neutral. It was fine for the 20 minutes of driving before. I dont understand this at all. H2a5 trans.
    Are your select cables in tact? What about the other gears?
    YouTube Clicky!!
      Cables look good and they are on like normal. The other gears are fine. Just 3rd.
        Try some honda MTF or GM Syncromesh
        YouTube Clicky!!
          I'll try and hope it helps if not i guess im gonna be pulling the trans out. Its just strange how it did it. You put it in 3rd and it feels like it goes in. Let out on the clutch and nothing.
            Changed the fluid and no change. Im going to pull the center console out take the cables loose from the shifter and the trans as well the see what happens when i put it back together.
              Uh oh, It sounds like it may be internal...maybe it will go away...err come back over time.
              YouTube Clicky!!
                Well no luck with the cables. So im gonna change out the trans. Oh well it is what it is.
                  Got the trans out and good thing in ways that it did this. Clutch wouldnt have made it much longer and the rear main seal is leaking. Should have it driving tomorrow. Gonna take the trans to my buddys shop and let him find out what happend with 3rd gear.
                    I know this is a bit late on telling you guys this. The trans has a bent shift fork. Thought I'd post this in case someone ever has the same problem.
                      Thanks. Late or not, it's still a help!
                      Nothing is more frustrating than searching a forum to find someone with the exact same problem, but no solution given!
                        No problem. Glad to help.
