I have a 1993 honda accord se coupe. I have replace uper and lower ball joints, iner and outer tie rod ends, uper controle arms, sway bar link bushings new axels and motor mounts. When im backing out of my driveway or any sharp turn and go from reverse to drive it pops very bad. I also have a major tire wear problem and it has had a 4 wheel alignment and eats the front tires off in the time it takes for an oil change. Any help here would bevery appreciated. Thanks guys. First post too.
front end pop.
Go over everything and make sure all bolts are tight. Take a look at anything the alignment shop touched especially.
Have you ever done a Carfax on your car? Is there any evidence of front end damage? If the car has been in an accident, that could account for the tire wear.
Are your shocks in good condition?
When you installed your axles, were you sure to push them in all the way? It is possible to reassemble the front end without pushing the axles all the way in, and problems can arise from that.
If you had an alignment, your shocks are good, your car was never hit, and your axles are installed properly... then my first thought is that the alignment shop screwed up.
Ive checked the front end and everything is tight. As for the car being crashed before i got it the guy ran off the road and broke the right front strut and brought it to my dads shop and had him fix it. Ended up puting both front struts on and lower front right controle arm. Since i got the car i took it and had it put on a frame machine and nothing is bent. But the front end pop is loud and the tires on the front getting eat off in 5000 miles has got old. The car has a slight pull to the right that didnt happen till it was aligned now that I think about it. But that axle was bad and shuttering on that side so I thought it was that.
Originally posted by F22A1forlifeMy next problem is on my dd. Its a 92 lx sedan 5 speed. For some reason it has no power down low at all. When it comes up to about 3500 rpm the sound changes and it will fly. Its got new plugs, wires ,cap and rotor button. New fuel filter air filter fuel injectors pcv valve and new timing belt. If you take off easy it seems like its dad on its feet and it jerks at about 1500 rpms like you stomp on the gas when i havent pushed ot down any farther.
