Well First this started out with just one brake light on the left not working at all and then both of them. This is on and off they don't always not work. I Checked the fuse. That was OK. I Test the light bulb connector Both lamps sides were getting power. I tested all the way back to main cluster. and i haven't found a short or any wear. I'm not the best with electronics but I really need to understand whats happening. Any Ideas?
96 Accord Brake Lights Not Working
Went to JY found new wires and sockets used brand new bulbs and now everything works great! But car does still have electrical issues like dome light was just replaced but stopped working and driver side switch will lower passenger windows but will not bring them up at all." Insert funny quote here "
For the dome light clean the contacts on the light itself and the balck contacts ont eh doors. Mine did the same thing when i got it. You shoudl also get another set of switches from the junk yard. Sounds like the "up" function is worn out...Procrastination is a THIEF of time!!
MY MRT
http://www.cb7tuner.com/vbb/showthread.php?t=203992
My First CB7
http://www.cardomain.com/ride/705233/1990-honda-accord/
