Originally posted by mikeBloko
View Post
F23 swap into 92 accord
They also click in reverse. If you know they are going bad you should address that as quickly as possible. A snapped axle can teat apart a clutch, flywheel, and transmission. Depending on the scenario, you could end up in a pretty bad accident.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
I just thought of something. Maybe the stock exhaust system in the cb7 isnt big enough in diameter to handle the f23 swap. Im thinking when my car gets up to temp that my whole exhaust system is getting heat soaked and causing that cracking/popping noise. Sure the f23 is only 98 cc's bigger but hey who knows, weirder things have happened. I almost want to cut off the stock muffler just to see if it will help it breathe better.
That is not your issue at all.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I think I figured it out. The stock cb7 exhaust ID is 1.75" while the 2000 accord LX which my motor is out of has 2.25" ID piping. Yes the bigger motor coupled with the smaller pipes should raise the exhaust gas velocity but maybe my cat or muffler are keeping the velocity down and trapping the heat in. I dont know this is driving me nuts.
Originally posted by mikeBloko View PostI think I figured it out. The stock cb7 exhaust ID is 1.75" while the 2000 accord LX which my motor is out of has 2.25" ID piping. Yes the bigger motor coupled with the smaller pipes should raise the exhaust gas velocity but maybe my cat or muffler are keeping the velocity down and trapping the heat in. I dont know this is driving me nuts.
If your exhaust is making a clicking noise, its probably just the heat transfering from the pipe to the heat shield. Mine does this as we speak cause it rubs and I can hear it clearly both when at idle and when the car is off. Its a clicking noise. Its just he metal contracting and expanding though and is nothing to worry about.
I just put an F23 short block in my wagon. I'm in awe at the difference in power it has brought with it. But I have no speedometer at the moment so I don't know exactly how much better it is, LOL. It just feels a lot more powerful. It sounds much different too.Last edited by Mishakol129; 05-15-2014, 08:56 PM.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
Originally posted by mikeBloko View PostI dont have a heat shield lol. I was just going to exhaust wrap it.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
