Fuel gauge is jumpy
    Fuel gauge is jumpy
    okay guys, so im driving today in my cb and finally wondered to my self why my fuel gauge is hopping around, this is the oldest car ive owned and im curious if its just because they used a dif way to read the fuel level or what?
    Can you post some pictures or a video so that we can see the exact fuel gauge readings over time?
    MRT
    14.38 @ 98.66mph
    The quest for 9s ceased, now the goal is a circuit track monster!
    Current fastest Laguna Seca Lap: 1:52.346
      camera phone sucks but mostly what i mean is when i take off it goes up when i stop quick it goes down alot
        From what your describing ,It sounds like you have an issue with the fuel pump sending unit.
          Very common for the sender to wear out over time given they're usually never replaced..
          happens more between 1/4-1/2 tank than any other position right?
          basically low fuel in your tank gives gravity more room to push the gas in your tank back and forth during stop and go. now there is a way to make it better, remove the fuel pump cap off and pressure ring, now if you can turn the whole assembly 1/4 turn left or right, replace the ring and cap and test it out.
            called it perfectly bamaland, always between 1/4 and 1/2... welll thats when i notice most. will deff try that out thankss
              fuel sending unit still available from Honda
              37800-SM4-A03 METER UNIT, FUEL (NS) , METER UNIT, FUEL
              37800-SM4-A04 METER UNIT, FUEL (DENSO) , METER UNIT, FUEL
