H23A1 Plenum on an F22A1?
    I have a plenum for the H23A1, will it work on the F22A1?
    Same question for distrubutor and coil...
    No and no.
    You'll need either the entire H23A1 intake manifold, or the lower half from an F22A6 intake manifold.
      I have the whole H23A1 engine. Will I be able to convert the distributor and coil?
        What do you mean by convert?
          Basically, I have an F22A1 that I want to put in my prelude and it has a good H23A1 in it. The F22A1 doesnt have the plenum, distributor or coil. Just seeing what I need to do to make it work.
            You can use the H23A1's entire intake manifold. I don't believe you can use the distributor. You will need an F22A distributor for that. 90-91 models were internal coil, 92-93 models were external coil. Get the one that matches what you have (external, I believe) and it'll plug right in.
              Awesome! Thanks
