It may help to address idle issues if you clean the IACV, adjust the FITV, replace all the intake gaskets with new and torque everything to spec.
If you're burning oil then you'll need to figure out where it is coming from first. Have you checked the spark plug tubes to see if those have oil? There is a spark plug seal above and below the rocker assembly for every plug. They're almost always bad on older Accords.
At the very least you can just get the manifold and hold on to it.
