So I was changing spark plugs last night and I found that 3 out 4 spark plugs had oil on it. How bad would it be to be driving the vehicle? How long until it gets really bad?
Driving with oil on spark plugs
I drove 500 miles with minor to mild leak in the tubes for a bit so you should be fine driving a few miles for parts. REMEMBER torque the rocker properly! I had the torque sheet that listed the bolts to be torqued slightly tighter than it OEM and snapped some of the bolts and resulted in a whole lot of BS.Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Oil on the tip will eventually cause the plug not to function. A plug that isn't sparking isn't causing the fuel to ignite. You'll be sending unburnt fuel into your exhaust manifold, and into your VERY hot catalytic converter. If it ignites after exiting the exhaust valve, major damage could occur.
You may not be at that point yet, but I'd suggest fixing it sooner rather than later. It's not a terribly difficult thing to do, but it could be a pain to fix in the cold if you're in an area that's getting frigid weather this winter.
You can reuse your plugs, just clean them in gasolin and let them dry=) They dont turn bad cause of that, the only reason to replace a spark plug is if it is physicle worn. There should be no damage to your spark plugs caused by oil.Last edited by Cb3vtec; 03-03-2014, 08:00 PM.
Originally posted by bobbycos View PostBetter question would be is the oil on the tip of the spark plugs or is it on the body of the spark plug
As implied earlier, to solve the oil leakage into the plug tubes, you have to remove the rocker assembly. Back off all the adjusting screws (if not before removing the assembly at least before reinstalling it) so that the torque on the rocker assembly bolts goes into properly clamping the rocker assembly to the head instead of compressing some of the valve springs. Then properly adjust the valve clearance and install new upper tube seals and valve cover gasket.
Originally posted by greenhornet614 View PostI have the same issue with my cb7 with oil in the plugs. Ill be getting the gasket kit to fix that issue once the weather breaks. Being in Ohio it's rough to work on cars in the winter.Last edited by Fleetw00d; 03-05-2014, 12:24 AM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
