Ok after soldering main relay (7 days ago) I noticed that my battery is always drained out and have to jump start or recharge the battery everyday. I don't know what causes this problem. New battery (less than a yr.) pls. help!
After fixing main relay.. Car always drained battery.
Originally posted by deevergote View PostThe last time I had that issue, the culprit was my starter. Apparently it's common for a failing starter to be the source of a power drain. It's merely as guess at this point, as there isn't enough information provided to really make an accurate diagnosis... but it's something to look out for.
Originally posted by sonikaccord View PostI had my compustar alarm hooked up and I think it eventually killed my battery, however, my car was sitting up for a while not being started or ran...
I unhooked it just to be sure but I really don't think that was an issue.
Didn't know that bit about the starter failing.
Ok....I have decided to drop 2 cents. I don't know how the main relay would relate but it might. When you shut the car off after a drive listen for the fuel pump humming. If you hear it open the gas cap. If you don't my two cents is worthless.......father in law has it back again. Time to shine
Originally posted by KuLaPhU View Postnever had this problem before until I soldered that main relay. is there anything in the main relay that causes the battery to drain?
It's possible that when you soldered the main relay you created a short circuit between two points that would cause power draw and drain the battery. This would be fairly obvious to anyone who has worked with electronics like this before though. Give us your thoughts on that; are you handy with electronics and a soldering iron?
Otherwise, you could try swapping main relays; if the problem goes away, then you've found the culprit. You could also try unhooking the main relay when you leave the car, and then plugging it back in when you're ready to leave. If the battery stays charged, then we can suspect the relay, or something down stream from it (like the starter).Last edited by reklipz; 02-26-2014, 09:11 PM.
