Good Day Mates,
Here's the issue with my 92 f22a1, after about 20-30 minutes of driving, the oil pressure light comes on @ idle. Rev the engine, goes off around 1k rpm's, stays off while cruising. Back on at idle, sometimes it seems to want to stall, quick rev smooth as glass.
The back ground of said engine/car. Full rebuild last year, head gasket was bad, traded out rx7 for all the work with my mechanic. We replaced, all seals and gaskets, head was pressure/vacuum checked 3 angle valve job done, new rings cause the pistons were ridiculously clean. Now for the bottom end fun, he did a lot of research about the different color bearings, and sent the crank out and it milled to one bearing size. Also replaced the water pump, and the timing belt stuff as well.
After about 2 months of driving, the oil light started flashing on at idle after she's warmed up. Took it back to mechanic, changed sending unit, doesn't come on as often, but still does nonetheless.
I thought about changing the oil from 5w-30 to 5w-40 to see if that helps?
Any input would be great, Thanks.
