Hey everyone I know this is probably a noob question but. How does driving a CB without power steering feel? I haven't had much experience driving without it. But I have driven an EK an EG and a 2004 Civic without it, I guess it wasn't too bad. But I know that an Accord is heavier than a Civic. I pretty much want to know if its worth it for daily use, I'd rather get a bit of feedback before I just say screw it and delete it when I put in my H22. Thank you for the help guys.
Power steering delete questions
Its tough at slow speeds without a manual rack conversion because you're fighting the hydraulics still (the fluid in the rack, compression, etc). I will eventually have to lose the PS in one of my cars and I'm hoping to do the DIY for the manual rack conversion but its not that easy to do, nor do I want to do it. But in the manual rack everything is loosey-goosey and there's no fight.
Originally posted by sonikaccord View PostTake the belt off and try it. I'm interested in this answer from people who have done the manual rack conversion. They say it isn't bad. Our car isn't much heavier than an '04 civic.Originally posted by cb9lovewhen all the cali cb's get forced off the road send em back too Ohio, we will still run them cats or not.
Originally posted by Raf99 View PostIts tough at slow speeds without a manual rack conversion because you're fighting the hydraulics still (the fluid in the rack, compression, etc). I will eventually have to lose the PS in one of my cars and I'm hoping to do the DIY for the manual rack conversion but its not that easy to do, nor do I want to do it. But in the manual rack everything is loosey-goosey and there's no fight.Originally posted by cb9lovewhen all the cali cb's get forced off the road send em back too Ohio, we will still run them cats or not.
The hydraulic fluid keeps the collar on the rack (16) and gear box cylinder (8) lubricated and cool. If you are not running fluids through the cylinder it can overheat and cause the rack collar to gall the cylinder wall and possibly seize.
In a manual rack conversion you cut the collar off the rack (16) and grease up the rac and ends of the cylinder. Also ensure that you have enough grease on the pinion shaft worm gear (14) and the rack(16).
