Dont know what this part is
    CAn someone tell me what this is for? and if i need it?
    Originally posted by devilslettuce66 View Post
    [img]http://s34.photobucket.com/user/chri...g.html?filters[user]=139317439&filters[recent]=1&sort=1&o=0[/IMG]
    For some reason you have some sort of filter or extended tagline on your Photobucket [IMG] link that will not allow me to see the image.
    Edit~ I found the proper IMG url;
    That is part of your cruise control. You only need it if you want to keep cruise control.
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      Thanks, sorry bout the shitty link
        what's it called and what does it do?
          Did you not see Ghost's answer above?
            Ok I'm asking for the actual part name and what's the function of that part specifically in regards to the cruise control smart guy!
              Is it possible to delete that? Is that a hydraulic line?
              My cruise control doesn't work and I don't ever really use it on my CB7. I'd rather delete it to clean up the engine bay.
                I'm not trying to be a smart ass. But after Ghost told you which system it is a part of, looking up the cruise control system for a cb7 is a very easy thing to do. The both of you need to get yourself a manual. That is one of the very first things any gearhead should get a hold of before touching their car.
                PM sent.
                  I don't have cruise haha it has all the switches though =/
                    For those of you who require spoon feeding, that is the cruise control Actuator Assembly, wire support, actuator stay (aka bracket) and cruise control actuator cable.
                    If you want the exact part numbers you will have to do that research on your own.
                    Yes you can remove it, no it is not a hydraulic line... have you even opened the hood of your car to look at it? It is a cable and vacuum hose or two. The vacuum hoses will have to be capped or completely removed and the source capped.
                    MR Thread
                      Thanks.. that's alot of detail and what I was looking for. I was just wondering if anybody was familiar with doing it. I have a haynes and recieved a good FSM. Thanks for your input. I'll be sure to try to get those caps so i can hop to it. I was looking to free up space in my engine bay since it's so packed.
