I have a 1990 Accord 4door lx 5spd. I got this car bone stock and I'm looking to build the suspension first. I've seen TruHart springs and struts advertised before for other vehicles. Not much feedback though. I was wondering if anyone has used or know anything about them. I can't seem to find spring rates just 2.5 front and 2.25 rear drop. Thanks
TruHart Suspension?
I would be cautious with unknown rates with that much drop. Call or email the manufacturer and make sure you ask for the rates in lb/in.Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Agreed. Total crap.
Also, stay away from anything made by KYB, or lower-end Tokico if you intend to lower 1.5" or more. They just aren't valved to handle such a drop (and most springs on the market will lower a minimum of 1.5" to 1.8".) Tokico Illuminas will handle a drop, but they're nearly as pricey as Koni Sports (Yellows)... and inferior in every way, in my opinion.
Koni Yellows are the best you'll get for a reasonable price, and they'll handle whatever you can throw at them. They're not cheap, but you get what you pay for.
Bilsteins are also fantastic, but I don't believe they make anything truly performance-oriented for us. You'd need to have a set revalved to properly handle a drop, and that will certainly get expensive.
If you are going to lower your ride that much, you'll get negative camber. I don't know if you will want to correct that with a camber kit, but I would, since I'm a stickler about my tires wearing evenly.
Check out the sticky thread in the Beginner Appearance Section titled: "Common Beginner Appearance Info can be found in here...."
and go to the Lowering FAQs page.
Or, here is the link: http://www.cb7tuner.com/vbb/showthread.php?t=470
I know a lot more after I read it.
MRT
14.38 @ 98.66mph
The quest for 9s ceased, now the goal is a circuit track monster!
Current fastest Laguna Seca Lap: 1:52.346
I know that Megan racing is one of those brands to stay away from in general, and the forum supports Ingalls products, but what about SPC Performance camber kits? They make kits for 1.5" max drops and 3.0" max drops. The full 1.5" drop kit is $300.
MRT
14.38 @ 98.66mph
Megan Racing makes knockoff products (like OBX). They do no real R&D of their own. They only copy designs made by other companies, and likely use inexpensive materials and manufacturing processes in the production of their products.
I have heard decent reports of their full coilover system (which isn't nearly as inexpensive as most of their other products), and I've heard that it's a copy of the Tanabe Sustec system. Still, I wouldn't waste my money on it. There are far better options out there.
Personally, I prefer a static spring with an adjustable shock... so H&R or Neuspeed springs paired with Koni Yellow shocks are ideal for me. If you want an adjustable setup, Koni Yellow shocks and Ground Control coilover sleeves are a great option. There aren't many reasonably-priced full coilovers for our cars that offer any real performance. Function and Form Autolife has some decent offerings, but even they say that their suspension systems are good only for amateur track use. If you want to do anything more than the occasional track day, you'll need better.
For a camber kit, see the brands i mentioned above. Don't go cheap there. I made that mistake, and almost lost my car (maybe even my life) when one broke at 65mph while I was in the left lane during rush hour. Thankfully, a very small piece of metal held until I got home (less than 1/4")
Strut bar... you can go cheap there. I actually have a Megan Racing bar in my car at the moment, and I'm pleased with it. It's a knockoff of the DC Sports design. There are better bars on the market (the bars made by ESP, and the Neuspeed 4 point front strut bar... only good on cars that don't have a DOHC engine swap, however.)
http://www.explicitspeedperformance.net/ESP3.html
"Installed pictures of the CB 90-93 Accord 3 Point Front Upper Strut Bar. As you can see plenty of clearance with the H swap. Will work with all F/H Motors."
Yes, the ESP bars are compatible with DOHC engines. I wasn't clear in my post. I just meant that the Neuspeed bar doesn't fit!
ESP made those bars above largely due to the requests of members on this forum. Guys with H swaps were bummed that they couldn't use the awesome Neuspeed design, and ESP provided us with another option that was superior to the standard 2 point design. The fact that it's a solid brace, rather than an adjustable one (like the DC Sports design) makes it superior as well.
Originally posted by deevergote View PostYes, the ESP bars are compatible with DOHC engines. I wasn't clear in my post. I just meant that the Neuspeed bar doesn't fit!
