Originally posted by illinois_erik
View Post
Lowering my car
Bilstein or Koni for shocks. For springs, it really depends on what you're going to do with the car. For daily driving, I LOVE my Bilstein shocks paired with the Skunk2 sport springs. Progressively wound, they're very nice and soft when I'm just driving around; the shock valving is definitely firmer than necessary for the softer rates, but once in a corner, the springs firm up VERY quickly and work pretty well. It's not as focused as it could be(I autocross my car, so it could be stiffer), but it works well for day to day use. If I was really shooting for doing the best I could in autocross, I'd either go with a set of revalved Bilsteins(they're pretty much a race shock, do some research), or the Koni yellows(if I didn't have any interest to revalve) paired with either Ground Controls in a custom rate, or a set of coilovers made from stuff like Summit Racing/QA1. It would not be a very streetable setup, IMO. My Bilstein/Skunk2 combo is just about all I would tolerate on the street, then again roads around here SUCK.
Skunk2 springs are crap. They don't know a damn thing about Accords.
Bilstein doesn't make anything for us that is valved for stiffer lowering springs. They make very high quality products, but no real performance products for our chassis. To properly use them with any performance springs, they must be revalved.
Originally posted by buzz11 View PostSince you're lowering your car, make sure to get some camber kits or else you will go thru tires fast. That plus an alignment will help keep tire wear to a minimum
I've had my wheels/tires for 9 months now, with no camber kits, and I have no uneven tire wear, even with -2.5 degrees of camber all around. I had the car aligned right after install, so the toe was set to zero. Camber doesn't kill tires fast.....toe does (especially camber + toe). If you have a drop less than 2in, a camber kit isn't needed......or even at a 3in drop like me. It would help, but you will be fine without it.
Camber wear still occurs. The choice of tire size and compound, combined with driving style and the health of other suspension components, will have an effect as well.
Best to tell someone the RIGHT way to do things, and let them decide for themselves whether or not they want to do it.
Negative camber causes uneven wear. Period.
Bam!
H&R part # 31851-1
Hunt around you can find them cheaper than MSRP.Last edited by illinois_erik; 01-21-2014, 05:19 PM.
I have this exact set. Best bang for your buck in my opinion. But then again.. I got them for alot lower than buying them separate.
Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
Originally posted by deevergote View PostCamber wear still occurs. The choice of tire size and compound, combined with driving style and the health of other suspension components, will have an effect as well.
Plus, if you plan on tracking the car like I do, some camber is a good thing lol.
Originally posted by illinois_erik View PostBam!
H&R part # 31851-1
Originally posted by Corweena View PostHow cheap can you find them for? I did a quick Google search, and came up with around $900 for the combo.....which seems to be quite a lot. I know H&R is good, but is it really worth $900....for a set of lowering springs and non-adjustable shocks?
Originally posted by Corweena View PostAh, the part number you gave pulled up the Sport Cup Kit.....which I guess is a more aggressive drop.
Isn't there a full write-up on this topic and the camber topic?
We should tell folks to go read that whole thing, then come back with questions. Not sure if I'm the only one sick of seeing this question asked and no-one pointing them to the proper documentation.
http://www.cb7tuner.com/vbb/showthread.php?t=139318
Originally posted by deevergote View PostSkunk2 springs are crap. They don't know a damn thing about Accords.
The Bilstien HD's are valved a little bit stiffer than factory(much stiffer, actually), and can easily handle the rates of 99% of the lowering spring kits out there. They also have shorter shafts and reversable spring perches to properly get the correct preload on the spring and overall height. I know because I installed mine myself, they're VERY nice pieces. With a revalve(as I stated before) they're basically a race shock depending on what's spec'd on the revalve. It's mind blowing the Honda community really hasn't embraced them as much as almost every other community, but then again, Honda's are the king of cookie cutter bolt on garbage.
If you can find some justification for the statements other than just random internet rambling from people who don't know what they're talking about or have heard from a guy who has a friend who's dog's sister's aunt's brother had them, I'd be happy to hear about it. Just because I have minimal posts on this board doesn't mean I'm an idiot and have no idea what I'm doing or talking about.
As far as camber wear, I have zero, but my suspension is in pretty decent shape with newer ball joints. No alignment since I've lowered it, easily 5,000 miles on this stuff now, on really soft compound snow tires.
