Strange Idle
    Strange Idle
    This has been a problem every since I replaced the main relay last summer.. but here it goes when I drive my car it drives fine runs fine but when I put it in park with the engine running the motor revs up and down continuously never calming down to a regular low idle just goes up and down until I put it in gear and drive off...it does not do it when I first start it in the mourning only when i been riding around and park it is when it goes crazy. I have check to see if the throttle was sticking but it wasnt ..weirdest shit I have ever seen my car do...any help will greatly be appreciated
    The thread at the top of this section marked "read this first" shows you how to fix this incredibly common problem.
      Thanks
        I have the same idle problem and I really want to fix it... this is all day everyday... idle goes up and down , in neutral and when I turn it on. also my cluster marks the temperature every now and then not all the time.. weird.. u think I might need a new cluster?
          1st, follow the advice I gave to the original poster.
          2nd, don't dig up someone else's thread only to change the subject. I guarantee the next 3 replies made to this thread will be to the original question, not what you just asked.
            My advice...
            Follow Deev's advice! This site has helped me fix innumerable issues, it just requires the use of the search function, unless you are on a smartphone, which it doesn't work on.
            Originally posted by crazymikey
            I thought a toaster with wheels was pretty cool....
              When is the last time you cleaned your idle valves and throttle plate? Get some carb/throttle cleaner and go to work. Look up ericthecarguy how to fix honda idle issues video.
              This is a must do if you haven't even done it at all. You will be suprised how much smoother your ride will become.
              Word of the wise: Don't worry about the car having trouble starting after you have it cleaned. Your ECU has to reset and recompensate for the increase in air that's coming in. After that your engine should purr at 800 and around 1500 on cold start.
