Here's my question what causes the steering wheel to shake and vibrate like hell when stopped at a red light while the car is in gear with a automatic transmission? It happens when the car is warmed up completely when its in gear but still runs normal once i take off....its very annoying
Shaking Steering Wheel
Front motor mount
C-3PO's MRT USDM yo!
what's you're idle at ?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
If the mounts are still good, what should I check for next?
Well let me update you guys on the progress.... I replaced one of the mounts drove it and it shakes a little when I stop but not as bad as it was so i guess its fixed ..I havnt been driving the car as a daily driver cause I still have a lot work to be done on it so really its a weekend project but I think the shaking is resolved.Last edited by yunghogg93; 01-27-2014, 11:13 AM.
Idle should be around 800.
The mounts are most likely the issue. Check them first. You've had two weeks since people first started giving you advice. At this point, everyone else is putting more effort into diagnosing your problem than you are. If the mounts are good, then we'll try to figure out what else it could be.
Please learn to use the "edit" button, rather than posting repeatedly... or you'll find that your thread has been deleted and your post count has been reset.
