Took my car through for the second time and failed emissions (high CO). It was lower this time around because I cleaned the EGR ports up some. I know causes can be a bad catalytic converter/o2 sensor amongst other things. Can an o2 sensor be bad without the CEL light on?
Failed emissions
Its unlikley your egr cleaning helped.
Yes its possible about the 02 sensor.
Post all your numbers.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
when was the last time you changed you're oil , pcv and did a good tune up ? old oil can have a affect . also the line that goes from pcv to the intake . is it cloged , collapsed ?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Delaware smog check and car inspection | DMV.org your welcome all from google.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
I cant see the last set of numbers on my phone.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View PostI cant see the last set of numbers on my phone.
Originally posted by Accord problems View Postwhen was the last time you changed you're oil , pcv and did a good tune up ? old oil can have a affect . also the line that goes from pcv to the intake . is it cloged , collapsed ?
Originally posted by Accord problems View PostDelaware smog check and car inspection | DMV.org your welcome all from google.
If thats co2 at 12% then your cat is not working or you are running stupid puke rich.
Co2 should be above 13%What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
so what's the verdict ?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
