So I pulled my distributor apart today and I knew before hand that my rotor was pressed on rather than screwed on. But from my research from other forums, my dizzy is supposed to have a threaded hole for a screwed on rotor but I don't have one. Is that normal ?
Question on 91 internal distributor rotor
mine aint it's screwed .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
yup i guess it matter's where you're car or engine / dizzy is from .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
