Okay i have a 92 ex coupe with a f22b2 from a 94 ex coupe. I redone my heads and i found that a few plugs were cut from the harness and missing. I want to replace the whole harness but what harness do i need? 92 or 94 engine bay harness? any help is appreciated!
Wire Harness?
If its a b1 it says vtec on the valve cover. The next place to look is on the block it will say f22b1 or f22b2. Did you buy the car with the swap? You should look into what ecu you are running. If it is a b1 you might have more work in front of you.......father in law has it back again. Time to shine
I know i have a f22b2. i meant was the stock harness in my car a vtec harness from factory because its an ex. I have the correct ecu. i already checked that. and i bought it with the swap in it already. i redone the head and had it port and polished with all new gaskets. also i swapped to a internal coil dizzy. while doing so i noticed wires where missing and plugs were broke or missing.
