f22a4 engine not starting when hot
    I just put another head on my car and now once my motor warms up it shuts off on its own, and will just turn over when trying to start it.
    Where should I start looking for what's wrong?
    is it the a4 head you are using?
    visit vgruk
      Maybe the Coil in the Dizzy.
      steve
        Its got the a6 head on it now and the 2 weeks before this past Sunday the dizzy was sitting in my car inside a garage while the motor was waiting for a head.
        I pulled the main relay and opened it up and smells a little burnt. Could that be my problem?
        Also I keep going through the 50 amp block like fuses for the ignition in the under hood fuse box.
          I doubt it's the main relay but it's worth looking into.
          Common main relay problems are difficult cold and hot starts ps, and unable to start for a few minutes after stalling the motor
          Did you check your spark plugs? They can tell a lot about what's going on inside your cylinders like tire tread.
            Ok so I changed out the coil and started right up but I turned it off to change out the upper radiator hose clamp and once again not starting. I checked for spark but there is no spark. So what's next?
              the igniter modul in the dizzy, you can also resolder the main relay just in case.
              MRT:http://www.cb7tuner.com/vbb/showthread.php?t=164408
              And on the eight day God created Honda!
                Check valve clearances and adjust them as needed.
                A&P-IA
                  could be ither bad dizzy or your main relay my car used to do that when it warmed up id shut it of and would not fire up but still crank over just wouldnt start so i did alot of work dizzy ect and once i changed my main relay it spoted . hope you fix it soon goodluck
                    Valve clearances were just set on sunday
                      Run codes. Can be a bad coolant temp sensor. Our cars depend on that sensor.
                      Main relay, you can figure it out if you see the check engine light turn off followed by a click when you turn to ignition. If you hear a click and crank it and it doesn't start then its NOT the main relay.
                      But if your saying no spark, im leading towards coil/dizzy. OR loose or yucky ecu ground on thermostat housing. Take it off and clean it.
                      Retro!
                      Hater
                        That ground is clean. This weekend I'm gonna see about getting another dizzy and putting on there to see if that fixes the problem
                          Before you do that, see if the coil is getting power when it dies.
                          Retro!
                          Hater
                            Well it turned out that my icm was bad so I changed it. And now I have to change the fuel pressure regulator, cause its just pouring gas in my motor right now bad enough its coming out the exhaust.
                              Ok so I changed the regulator out and its still pouring white smoke our the exhaust. Is there anything else that it could be?
