Stubborn EGR code
    Stubborn EGR code
    Hey guys, so I've been having some idling issues as well as a check engine light, I've read the CEL sticky, as well as the erratic idle sticky. I had 3 different codes showing but now I've got it down to just code 12. I used TB cleaner and sprayed the hole in the intake where the egr bolts on, bought a new egr all together, and I cant seem to get the code to stop coming back. Any ideas?
    Perhaps you need to clean out the EGR ports.
      Is there anything else you would consider before i go ahead and drill those plugs out?
        Check your wiring. Maybe try another ECU if you have access to one. It's unlikely that the issue is ECU-related, but it's easier to unplug a box than it is to drill out ports!
          Very true lol. I've got a buddy whose got just about 5 ecu's for F series so ill look into that, but let me ask you this, the car had an a6 in it from the factory, its got an a4 now, do they have different ecus?
