my speed ometer was working fine out of no where started bugging out jumping all over the place then stoped working i changed the cluster and speed sensor but still wont work anyone had this problem?
speedometer problem
Did the odometer and/or cruise control still work when the speedometer was acting up? The VSS provides a signal for all three, so if any one works consistently, it is not the VSS. Did you check continuity of wiring between the VSS and the cluster? Are you sure the cluster you installed was good (they sometimes have corrosion problems on the printed circuit board)?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
