The car I had before this was a 2004 Cavalier which had only a 14 gallon fuel tank plus our prices around here average around $3.10-$3.20 that's why most of the time when I had to fill up the most I used was around $35.
filling up with gas
in that case i have a big issue then . i got to keep track of how much i putt in . if not it will flow out no matter where i go .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
If you read your owner's manual, "Do not overfill the tank; fill only until the gas pump clicks off automatically and never top off."
Don't count on a full 17 gallons in the tank. That may be its total capacity, but its usable capacity is only about 15.5 gallons (I ran out in my wagon once and managed to coast into a station, took 15.4 gallons).Last edited by Fleetw00d; 09-27-2013, 11:42 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by evil_demon_01 View PostNo, it doesn't have to seal to create pressure.
Think of filling a jerrycan, it is definitely NOT a tight fit at all, therefore almost no back pressure.
You could fill an open container and the pump will stop as soon as you put the nozzle in the fuel.
The pump cuts when the nozzle is physically in fuel, not by the amount of back pressure.
One click is what it says right on the pump as well. Further more with the new stage 3 blah blah blah nozzle anything beyond the first click will circulate back into the pump. That's what it says on the pump. Anything past one click is a waste of money.
I've driven till the gas light was on dozens of times and even had some sputtering without ever getting to a 15 gallon fill up.
And my 1991 civic si would only take about 10 gallons so if the price is right that would be about 35 dollars. It was only 10-15 dollars to fill up back when I was driving it.Last edited by cb7 calling; 09-28-2013, 06:49 AM.......father in law has it back again. Time to shine
