Hi all,
My Accord refused to start on me. I checked the LED light code on the ECU and it gave a 15. Following the diagnostic in the Service manual, I removed the "Backup" fuse for 10 sec., and replaced it. Tried starting again, still won't start, but now not giving any CEL at all. I've ruled out the main relay, spark plugs, distributor cap, and ignition rotor. I don't think it is my fuel pump either, as I loosened the fuel test port and turned the key to position 2, and fuel seeped out, so that indicates to me that the fuel pump is good (though I could be wrong, as that isn't necessarily a good test. Anything else I should check? The service manual says that if I don't get a check engine light after the procedure above, to just check a couple connections. Thanks for any advise!
