93 lx short shifter troubles
    I have been looking all over for a short shifter that directly fits the 1993 accord, but i have had no luck.
    is there anyone who knows a close enough match up between models that i could use instead of one designed for my year exactly?
    There really isn't one. The thing to do is use a shifter out of the 92-96 prelude and then go from there.
      do you know if it will directly fit?
        Yup.
          There was a company a while back but I can't remember there name. Also I made mine with a washer and welder. Took all iof 5 mins.
          my new turbo build
            thanks for the info, i figured going for a custom one would be the best option.
              ebay
              obx makes a shifter direct bolt on for cb7s
              i have it and works perfect never had a problem
              i believe they are like 50 shipped
                i havent been able to find one for it on there at all.
                  OBX, Neuspeed, and a number of others make adapters, not the actual shifter. You can also make your own adapter for about $3 that works just as well.
                  P-Spec and Forbidden made shifters that we could use, but both have been discontinued. The actual shift lever does nothing different than the adapter, aside from costing more.
                  All a short shifter does is change the location of the cable mounting points on the shift lever. This usually causes gear grinds.
                  It took me all of 10 seconds to find one on Google...
                  http://www.sparktecmotorsports.com/o...tm_content=pla
                    Thanks for the info, i really appriciate it!
