engine swap h22a into f22a
    Hi guys i'm clueless about cars i have a auto prelude 2.2si 4th gen with f22a engine. Recently engine blew so i'm wanting to put in a h22a vtec instead but was told that because my cars an auto it can't be done i would have to switch in a manual gearbox is this true?.
    Also what would i need to do if it does fit and is it an expensive swap. gearbox is 4 speed.
    And last the h22a has damaged sensors can i use any of my f22a sensors?
    Thx
    The H22A will bolt in fine. I'm not familiar with auto swaps so you may have to swap a mount out or two to make it work correctly. You also need the correct ECU and harness to wire to make VTEC work correctly.
    Which sensors are broken?
    As far as budget, I would plan for at least $1000 for the motor, and if you can't do this on your own, perhaps anther $1000-$1500 for a shop to do it.
    '94 JDM H22A: 178whp 146wtq
      Thx for the prompt reply
      The throttle body sensor and egr sensor ,egr valve also . Can get the engine for 700$. I heard that a generic ecu(not sure what u call it) can work and it also can substitute for broken sensors.
        That would be what we call a "chipped" ECU. Basically, people use an ECU from another car that has been modified so that it can be programmed... it's NOT a good way to do a swap initially. Get it running on the proper ECU first, then worry about changing things.
        Look at the "Swaps" section of this site. The "Sticky" threads at the top show how to do the swap in a CB7. It will be even easier into a Prelude.
