shock setup question
    It might be a obvious answer to the question but can I just buy 2 shocks at a time? I'm need of some shocks and right now I'm stock. I'm looking to get some KYB adjustable's. Will my ride suffer because I'll be riding on two stock shocks and then two aftermarket shocks? I wish I could get all 4 at once but I can afford 2 at a time.
    2 at a time is better than riding on what you have, if what you have is blown.
    The KYB AGX are pretty stock-like on the lower settings, so it should be fine. Get all 4 as soon as possible, though.
    Also, if you are lowered, or plan on lowering... I truly do not suggest anything by KYB. While they make great shocks, they don't make anything that is designed to be lowered more than 1.5", or with a spring rate higher than 15% over stock (this MAY not be an issue for the AGX, but I wouldn't risk it.) I've had AGXs on H&R Sport springs in the past, and I managed to pop one. Going to Koni Yellows was like night and day. CONSIDERABLY better... comfort, performance, and reliability. I've never damaged a Koni, and I've gone lower since.
      If I do lower it will be less than 1.5" most likely. I was reading that thread on the suspension section and it seems Eibach is a good brand to go with if I don't want to lower it that much.
        Yeah, Eibach is one of the few companies that offers a spring that will lower a very slight amount. I believe Tein has such an offering as well.
        Be aware, less than 1.5" will hardly be noticeable, especially in terms of appearance. You'll likely notice a performance improvement, but you won't see much of a drop. Personally, I like it that way. I don't care for slammed cars... I guess it comes with old age!
          We have something in common Besides that I don't want to go to low the roads around here are not the greatest plus I usually have more than 2 people in my car at a time. I don't want my car to bottom out.
            I have eibach prokits with the agx struts. They are ok. My dad rides on level 1 in the rear and 3 in the front...its firmer. We got crappy roads here so its decent. But if you have nice roads then the rear at 4 is beautiful.
            The drop is very minimal, maybe a little over a 3 finger gap.
            I was thinking of selling my agx struts to, just don't know if I can find another set of struts for a decent price anytime soon.
            Retro!
            Hater
              ProKits are a bit low and stiff for the AGX. Like my H&R Sport, one pothole could end it for one of those shocks!
              They're not terrible (my friend is still riding on my old setup... has been for half a decade now), but having a properly matched setup is SO much better all around.
              I will never have anything but Koni Yellows on my car... unless somehow, something better comes along.
                Ok I'm going to reply here instead of starting a new thread. I decided I'm not going to lower my car. I do want a nice upgrade through. Which ones do you recommend for an upgrade from OEM? I plan on getting some sometime this week.
                  Koni Str.T's. Got mine a couple months back for $238 shipped.
                    Koni STR.T is good. KYB AGX is good on stock springs if you'd like adjustable shocks. Stiffen them up for play, turn them down for comfort.
                      Thanks I'll look into them. Should I replace something else while I'm there, like my strut mount?
