My 93 lx has been pushing coolant into reservoir and after a couple mins the check engine light will come on when the ecu is jumped the o2 trouble code comes on. But after engine is shut off and restarted no check engine light? Btw cars been drinking coolant and upper radiator hose is extremely hot/pressurized. Thinking the head gasket blew and exhaust is getting into system but not sure exactly yet, any thoughts?
Check engine o2 sensor/head gasket
If the head gasket is blown, you'll be blowing white smoke from the tail pipe. Burning coolant could certainly foul the o2 sensor. o2 codes tend to come and go. It's irritating.
If the upper hose is pressurized, it's also possible that your thermostat has failed. I'd start by replacing that, as it's cheap and easy.
Originally posted by deevergote View PostIf the head gasket is blown, you'll be blowing white smoke from the tail pipe. Burning coolant could certainly foul the o2 sensor. o2 codes tend to come and go. It's irritating.
Yes it bubbles and i am going to reinstall it later tonight, the thermostat that is
Originally posted by cloudasc View PostA bad radiator cap can cause the overflow bottle to overflow, how old is the radiator cap? You say you have an o2 code, which one(s)?
If it bubbles with air while it's running that is usually a sign of a leaking head gasket and compressed gasses getting into the coolant.
If you can you should see about getting a coolant system pressure test done. It will show you where your car is drinking the coolant from.
How does your oil look? Not that it matters, coolant doesn't always mix into the oil pan with a blown head gasket. On the other side. Does your radiator or over flow coolant have any signs of oil spots?Last edited by GhostAccord; 08-16-2013, 07:50 PM.
Originally posted by Avcb7driver View PostI just changed the oil to penzoil 10w40 since where i live it gets super hot, on the dip stick the old oil looked like it had water but when i drained it it wasnt bad at all, gonna try some blue devil head gasket sealer and see what happens1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
I remember Geoff posting something on the heater core in his car. If I recall replacement was a bitch.
If its too hot where you are now you could just bypass it by connecting the two lines at the fire wall.
I'm not positive my idea will work and don't know if it will cause any harm, other than no heat.
steve
Blue devil does no physical harm to a engine. I have known many people to use it. And it will hold for a long time. My headgasket had it put in by previous owner. Finally gave out 30,000 miles later. I changed the head gasket and only way I noticed it was in there besides him telling me. Was that the head gasket was coated in a thin layer of blue. The flush turned up nothing. Blue devil is one of the only products I would put in my car as it does not harden when put in. Just make sure you follow instructions to the T.
Easy way to find out if the heater core is clogged take off one heater core hose. And put a water hose in your radiator start the car and if water keeps coming out of the heater core then it's not clogged. I'm guessing head gasket mine and honda ladies. Were doing the same exact thing coming out of the radiator.Last edited by andrew22888; 08-17-2013, 07:19 PM.
