Seafoam
    Seafoam
    Please can someone help me on how to get seafoam in Nigeria.
    Check your local stores. If nobody carries it in Nigeria, then you will have to have it shipped. You'll need to read the laws to make sure it can be imported. The expense of importing it might outweigh the benefits. It's a good engine cleaner, but it's not worth going crazy for.
      Hey Tai, what exactly are you trying to accomplish? Fuel injection cleaning? Clean carbon deposits? Clean intake manifold? Seafoam works only if done right, but Seafoam is not the only solution out there, bro...
      I've even seen someone use one gallon of lacquer thinner to burn off impurities within the fuel system and catalytic converter. But be very careful not to rev too high, just high enough to PUSH the cleaner through...
      "There are only two types of people in this world... Those who run & win, and those who sit at the sidelines & watch the winners pass them by."
      My YouTube Channel! - There's more videos here!
      Check 'em out, hit LIKE, or even better, stay updated with more vids when you SUBSCRIBE, including vids of my JDM H23A swap!
        lacquerNever heard of any one doing that . If you do use sea foam be careful . I have seen people hydro lock engine's using this stuff .
        Car safety checks
        Fluid Capacities
          Has anyone ever heard of this stuff doing damage to an engine, for example washingthe oil off the rings and pistons causing scarring on cylinder bores? Also, i would be hesitant to put this stuff in my oil
          Additionally, it makes me feel good to call someone a cunt if they don't say "thank you".
          So no matter what, I win. Selfish reasons.
            Car safety checks
            Fluid Capacities
              I saw your post, i just waned to bump the thread and see if ANYONE ELSE heard anything bad about it
                If you don't use it correctly, yes, it can do damage. It will eat rubber seals if left in the oil long enough. Many people suggest changing the oil twice after using it.
                Remove old oil, add new oil and seafoam, run the car for a bit to blow out all the crap... change the oil again with fresh.
                I, however, was a dumbass and ran with it in my oil for 4,000 miles... and I've had no problems many years later. My engine is a freak, though... I should've destroyed that thing a dozen times over by now!
