Hey I went outside this morning to start my car and I noticed evidence of something leaking out of the front. I think it must be coolant or ATF but I cant seem to find where it is leaking from. Me and my brother changed the radiator a few weeks ago and I'm wondering if we did something wrong. I am new to fixing cars so any help would be awesome hopefully someone has seen this before. Here's some pics
Something leaking out of the front of my car!?
That's about in line with where the radiator cap would be. The only thing anyone is going to be able to tell you is to pop your hood and look around. Check the upper and lower hoses, the overflow tank hose and the transmission cooler hoses if you have them. You might also run the car and let it heat up enough for the thermostat to open. Then check under the hood for fizzing or bubbling areas. You could have a pinhole leak in a hose or a leaking radiator.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Ya know I can't say something didn't pee on it! Haha but the rad is new along with the upper/lower hoses. I think it does have the ATF cooler maybe the hoses have a leak they were not changed or maybe I didn't tighten the clamps enough. I will let it run like you say and check it then thanks for the idea!
Yeah, it gets stuck in the cross member and the lower shield and as you drive slowly works its way out. After a while I dropped the lower shield and it had a big green stain on it, cleaned that off, wouldn't hurt if you do the same, so if it leaks again, you know it might be something else. Spraying lightly with a hose by the bottom of the radiator ought to flush that crossmember out.
I have that too but idk what it is. im gunna go check my hoses now. It might be my coolant overflow. but I never over heat.
C-3PO's MRT USDM yo!
Originally posted by 92exrkid View PostHow can I take the lower shield off my car to clean it and inspect underneath?
Originally posted by 92exrkid View PostSomeone at my work told me to taste it but I thought he was crazy still not doing it because I'm starting to wonder if it is piss
