i have a h23 throttle and i dont know if i need to tune the ecu can anybody help me
having trouble to make the rpm throw redline
Trying to decipher your english I come up with 2 things you are trying to say. 1) You're car isnt revving to redline. If that is the case then how high does it go, how does it behave? Could be dozens if not hundreds of reasons why it wouldt reach its redline but you need to tell us more. 2) You want the car to go past its redline. If thats the case then yes at a minimum a complete new tuned ECU. But the redline is there for a reason. After it you risk serious engine damage because your engine and its part are not designed to operate at those speeds. So if you want to go past redline more then once..you need to do some serous engine work first.
The h23 throttle body doesn't fit the accord intake manifold.
http://www.cb7tuner.com/vbb/showthread.php?t=29727
