My car makes a really awkward noise when I have the a.c. On. It wasn't doin this before. Like a yeek yeek yeeek noise. Any suggestions on what I could do? I mean I understand that the car uses more power with the ac on and shakes more but it didn't sound like this before
Loud noise??
Or you have a failing a/c compressor or compressor clutch.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Originally posted by reklipz View PostWith the engine idling and the transmission not in gear, pop the hood and try to pinpoint where the noise is coming from. Take a picture of the suspect items and post back up.
Alright il do that after work. So put it in neutral then?
My guess: your condenser is making the noise.
Originally posted by illinois_erik View Postsounds like you need a belt or the tension adjusted.
Originally posted by wildBill83 View PostOr you have a failing a/c compressor or compressor clutch.BLOOD ON THE LEAVES
And it will work up until the point it fails.1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by RoseRoyce View PostSo is there a way to fix the condenser or would I have to replace it?
If his condensor is leaking I doubt his A/C would be working correctly. OP states his A/C blows cold. With a freon leak in the condensor it would lose pressure, the A/C pump would stop pumping due to the pressure sensor sensing low pressure, and his A/C would blow warm air.
I have serious doubts it is his condensor.
Also your repair is incorrect, if you condensor fails you have to replace it as well as the filter/drier and immediately you have to vacuum the system to remove ambient air with moisture. Then your system must hold a vacuum for a few hours to over night and then re-charge on top of the vacuum using a correct A/C manifold.Last edited by wildBill83; 06-28-2013, 11:53 PM.1993 SE Coupe MRT - 1992 LX Sedan MRT
He asked about fixing the condenser. Its best to replace it than fix it if there is a problem with the condenser. I directly answered his question.
I forgot to add the drier/accumulator. But your repair is not complete either. You forgot about properly removing the current refrigerant. Not doing so can get someone hit with large fines.Last edited by SleepingGiant; 06-29-2013, 08:04 AM.
Originally posted by SleepingGiant View PostHe asked about fixing the condenser. Its best to replace it than fix it if there is a problem with the condenser. I directly answered his question.
OP disregard discussion of your accumulator, that isn't the source of your noise.1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by oyajicool View PostHow can a condenser make noise during A/C operation?
Apologies for the slip, OP! wildBill82 and oyajicool have got your back.
