I wanted to know if there were small things I could do to my car to make it a little faster. My 92 auto seems so slow. Any like cheap things I could do to make it at least a little faster? I know intake is one.
More power!
Originally posted by RoseRoyce View PostI wanted to know if there were small things I could do to my car to make it a little faster. My 92 auto seems so slow. Any like cheap things I could do to make it at least a little faster? I know intake is one.
http://www.cb7tuner.com/vbb/showthread.php?t=158531My MRT: http://www.cb7tuner.com/vbb/showthread.php?t=200048
(Turbo lag - turbo power) + HYPE = VTEC
Bought From: Davids92Accord
Sold To:
Keep in mind that it's a 21 year old economy car with an automatic transmission. Relative to many cars on the road it's not going to be very fast without extensive modifications.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
An intake will give a small bump in power, but if the filter isn't good, you'll be sucking in crap that will eventually kill your engine. Given that the engine is already 20 years old, that's not a good idea.
If you have an intake pipe, you can get a good filter for it. A pipe is a pipe. It's the filter that matters!
If the filter on your current intake isn't removable, then that's really lame!
Get a good cone filter (AEM dry flow filters are my favorite, though I don't have one yet... I envy my friend's) and just cut the old filter off the pipe if it's really not removable. You should be able to put the AEM filter on there as long as you get the proper diameter (probably 2.5", but measure it to be sure.)
A real tune-up includes valve adjustments, not just throwing new plugs and wires on. When was the last time you checked valve lash and clearance?1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
you need to do exhaust work to, bigger piping from the headers back, (not massive freaking fart can pipes you can shove your fist in) the better the car can breath the better it will perform, and dont go with a stock header, try to go for something without the ninety degree bend in it (from my knowledge thats what most stock headers have) find one that is angled smoother, exhaust gas is, bouncy per say so having that ninety degree angle in the header is detrimental to the performace. think of it like throwing a ball against a wall, as apposed to down a hill lol, thats the best simile i could muster
