Is there anyway to have my automatic 92 running smooth again? When I first bought the car , I could feel it shifting hard. It wouldn't shift until at a high rpm and when it finally did you could feel the jerk. I changed the trans fluid and it helped. But wasn't where I wanted it, so a co worker suggested Lucas trans oil. It helped a lot after that but a month later its starting to shift hard again
Rough shifting
Hopefully putting the lucas trans oil didn't mess anything up with your transmission. The automatic transmission holds over around 6qt's if I remember correctly, which requires at a minimum of 3 drain and fills to even come close to a 'flush', which by the way would be recommended since you added the Lucas. The only transmission fluid you should really use is Honda brand, any other brands require a special additive (that I can't remember the name of) to work properly.
Every time you drain and fill you are only replacing approximately 33% of the fluid. In your case I would recommend doing some drain and fill at very short intervals (300-500) miles initially to get the Lucas out. How often you should change the fluid can be determined by how black the transmission fluid that drains out of the transmission.Last edited by cloudasc; 06-23-2013, 05:00 PM.
Originally posted by deevergote View PostYou should never put any additives in your transmission. Ever.
Use Honda ATF only. Our transmissions are fairly sensitive to the fluid you put in them.
Is your D4 light flashing, by any chance? If so, that would be indicating a transmission computer error code.
Originally posted by cloudasc View PostHopefully putting the lucas trans oil didn't mess anything up with your transmission. The automatic transmission holds over around 6qt's if I remember correctly, which requires at a minimum of 3 drain and fills to even come close to a 'flush', which by the way would be recommended since you added the Lucas. The only transmission fluid you should really use is Honda brand, any other brands require a special additive (that I can't remember the name of) to work properly.
Every time you drain and fill you are only replacing approximately 33% of the fluid. In your case I would recommend doing some drain and fill at very short intervals (300-500) miles initially to get the Lucas out. How often you should change the fluid can be determined by how black the transmission fluid that drains out of the transmission.BLOOD ON THE LEAVES
Buy your fluid from Honda. Many fluids say they will work... and many do not. Use Honda fluid, not "fluid that Napa says will work".
Don't blame your friend. You followed his advice blindly. It's your car. You make the decisions.
Also, please use the edit button if you have something to add. Don't post twice in a row. My password is long and complicated, and I have to input it every time I merge posts. It's much easier for me to just delete your thread.
Originally posted by RoseRoyce View PostOh I see. That makes sence. I'll do a flush, drive for a bout 300 miles n repeat. Dam that's prolly gonna b expensive tho. How much is Honda trans fluid?
Don't go to E-bay or some site to buy the fluid. Your transmission was designed by very serious meticulous Japanese engineers. They spent many hours and days studying the mechanisms and what makes it run...they turn out products that if faulty, they are very upset and shamed. Thus..they know how the transmission works and they know and told us.."use only Honda fluid and none other" They didn't do this to make money..they did it because they made it to take only this to run perfect.
Think about that next time some "sales parts guy" at an Auto parts store says "Yea...this will work, it says for foreign cars " (he is holding a bottle of yellow pee for all you know) Do it right...spend the buck ..go to Honda.
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
I would say the motor\trans mounts.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
If a solenoid is going out, it will stay in 4th normally. You will also get a flashing D4 light fairly quick. I just replaced my shift solenoid on Monday. When you go to buy your fluid, ask the parts guy if they will give you a quantity discount. The guy here did and fluid went from $8.93 a quart to arounf $6 a quart. I bought 7 since I had to do a transmission swap.
