Pulled over by cops, brake lights out...
    Only the middle light works, got a fix it ticket, no biggie, BUT...
    Went home, took out the fuse, replaced with a extra one (10), nothing still. Checked the lights itself, nothing seems wrong, they're lighting up when I turn my lights on, but the brake light wont. What am I missing?
    Help please?
    I've never had to do anything with CB brake lights, and so maybe this is really stupid suggestion, but is there a separate bulb for the brake light from the regular rear lights?
    I know some vehicles/rear light designs have separate brake bulbs for the brake lights, so might be worth seeing if your CB has this and whether they're burnt out...
      separate bulbs for tail lights and brake lights.
      So are your tail lights out or your brake lights?
      have a look at this.
      http://www.cb7tuner.com/vbb/showthread.php?t=180225
      look at post #8
        look at post #8
        My daytime running lights work, my brake lights are out. There seperate lights? I see 2 bulbs, one is reverse the other is daytime lights I gather because when I turned on those lights, my lights lit up in the back, but when I hit the brakes, nothing lights up. Where is the brake light bulb at than?
          could it possibly be the brake light switch on the pedal?
            One of the first thing I checked, although I didn't see any foul play on first glance, I will give it a second look first thing in the morning, too dark out right now
              I think that's an awesome suggestion from Swiss, esp as it's weird that both burnt out at the same time, but didn't suggest it because you said the middle light was on:
              I thought you meant the middle brake light, the one in the housing in the cabin on the package tray. If this light works when you brake, then the problem can't be in the pedal switch.
              If the pedal switch is good and you're checking your bulbs, just pull the various bulb attachments out of the housing, turn your lights on, whichever one doesn't light up is the culprit (obviously the bulb in the clear housing is the reverse). Try a new bulb, if that doesn't do it, time to look at wiring....
                Aren't the bulbs dual-filament bulbs? That means that the filament for the turn signal could very well be intact while the filament for the brake signal could very well be broken. On both bulbs.
                  Turn signal has it's own bulb.
                  Taillight/Brake light is dual filament.
                  My 5.7 LS1 Holden Ute
                    Yep, just confirmed via the parts-store website. Get new bulbs, or check continuity on each filament before you buy if you are tight on cash.
                    Sorry, I mixed up "turn signal" and "tail light" in my post. Thanks for the correction.
                      I totally spaced the light working. Can I use the I was tired excuse?
                        Well, Im a idiot, it was the bulbs, both were burnt out and black inside, lol. Fixed, thanks everyone for the help
                          Atlest it was simple bro! dammn be happy for those stupid 1 ya kno,not welll guys i fount the problemits my whole wiring from trunk is friend,shorted gobbled the ecu lost tune ! huh
                          This thread is over a year old, you fucking retard.
                          i dont know why this popped up but U MAD BRO? not my fault u is FAKE! CLOWN ASS
