My cb7 smokes at startup then disappears
    I know I was just play in dude
    BLOOD ON THE LEAVES
      Can you take a video with sound? It could also be a small amount of oil pooling that got past the valve seals and seats that gets burned off initially or a head gasket that is beginning to fail and when the motor is off the coolant seeps into the chamber and when the motor is running the exhaust gasses escape into your coolant and the smoke stops.
      I suggest testing for exhaust fumes in your coolant.
      RoseRoyce, thread whoring or post padding by adding nothing to the technical discussion with a post is against the rules. I suggest avoiding that.
      Check out the rules stickied at the top of the forum.
        White smoke= coolant/water
        Blue-ish smoke= oil
        Black smoke= FUEL BABY!!! Because racekar
