engine "missing"
    engine "missing"
    I have a 91 accord with AT. Lost the reverse gear (grinding noise when put in reverse) so replaced AT with one from a 93 accord. After swap all was well for about 5 miles. Now the car will start fine, you can drive it, shifts into all the gears, when your reach cruising speed the car will start to cut out like the ignition cuts out. I can unplug/plugin the TCM and it clears up the problem, but it comes right back after about 5 miles, sometimes not even that long. There is a clicking noise coming from under the driver's side of the dash when the engine cuts out. Is there anything that I could have knocked loose putting the tranny in? It was pretty straight forward and I completed the swap in about 6 hours including new axles. The car was running fine before the tranny swap. There no check engine light and no codes no D4 light. Any ideas?
    A clicking noise under the dash is usually a relay. You might have messed up a grounding wire make sure all wires are in contact and none are broken. Hope this helps
      I already checked the ground wire from the transmission to the car body/battery. I have more than one working TCM and if you disconnect the battery swap them out and reconnect the battery the problem clears up for a very short time then comes back. What's got me stumped is there are no CEL, no flashing D4 light, and no led flashes from the TCM. Should I try swapping out the relays under the dash and if so which ones?
        Have you tried to switch out the TCM ?
          yes
            where do I locate the ground wire for the main relay? 91 accord LX 2.2L
              Check the ecu ground at the thermostat. Make sure its clean and tight.
              Retro!
              Hater
                Woo Hoo it's fixed. It was a loose ground wire from the thermostat to the ecu. Crazy. Thanks for all the help.
                  Glad you got it fixed
                  Retro!
                  Hater
