Car "sputters" "lags" until CEL goes on
    So here's the situation:
    Start car.
    Set to (D). Drive away.
    Before I can get to 20mph, car starts to ''sputter" and wont pass 3.5k RPM.
    It gets like that and slowly picks up speed but continues to sputter.
    Until finally, it gives way, and the CEL goes on, and it runs fine.
    I have no idea what issues it may have. A friend of mine says it could be the spark plugs. I haven't change that in less than ... say... 6 months before I changed the valve cover gasket because oil WAS getting into the spark plug chambers and I've changed the gaskets already.
    Any ideas?
    Are you getting and CEL when you start the car?
      It's similar to what I had experienced when I had new Bosch O2 sensor installed. Replaced that sensor with Denso O2 sensor and problem was gone.
      A&P-IA
        First step is to pull the CEL code and get back to us. We don't want shooting info in the dark.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          Nah, it only happens when I'm driving for the first five-ten minutes.
          Yeah I'll do that and let you know
          I'll find out the code first then see..
            Weird . Could be 02sensor or maybe a bad ecu . Not 100% sure pull your codes first .
              The ECU runs in what is called "open loop mode" on startup, and whenever the CEL is on. "Open loop mode" runs on a preset fuel table, rather than on feedback from sensors. "Closed loop mode" is how the ECU operates once the car reaches operating temperature. In this mode, it is constantly adjusting the fuel mixture using sensor feedback (the o2 sensor is one of the big ones.)
              A bad o2 sensor would cause the car to run very poorly once it has reached operating temperature, until that check engine light turns on. So yes, chances are good that the o2 sensor is indeed the culprit. When you pull that error code, it is likely to be either 41 or 43... or both. Pull the code. If it's either of those, replace the o2 sensor with a Denso or NGK/NTK unit. No Bosch. As oyajicool mentioned already, Bosch sensors don't work properly for our cars.
              Also, use the "edit" button if you want to reply to more than one post at a time, or add anything to a post. I see that a moderator has already merged 3 of your posts. It won't happen a second time. Your posts, maybe your entire thread, will simply be deleted.
                Thanks deever. Yeah Im on my phone and it's not as easy replying like it is on the computer. But I will keep that in mind for future reference.
                  Check your cel code. try simply unplugging the o2, if it runs better, start there.
                    Well, I still haven't checked the code, lol. But here's the update.. so far, the sputtering has stopped.
                    But, now when I start my car, the CEL goes on and now the car runs somewhat 'better'. As if nothing is wrong. But there should be! The CEL is on. haha.
                    But when I can get the homie to come around and check what code it is, I'll come back and let you guys know.
                    THanks.
                      come on bro it's not hard to do . check this out .
                      Car safety checks
                      Fluid Capacities
                        That was easy to do! Now I'll definitely get back to you guys with what the code is. Thanks!
                          Code 1 , 41 , 43 are the codes it's telling me
                            http://www.cb7tuner.com/vbb/showthread.php?t=21259
                            This will show you exactly what those codes are.
                              Next step is to search the meaning of those codes.
