ok ladies and gents, I have this pulsating idle it pulses between 1000 and 1500. I thought it was an exhaust leak. nope. fitv was deleted. I put a new tps, new iacv, last year from az. it went away when I deleted fitv but then it came back took the IM apart and resealed. it starts fine, but then I drive around push the clutch in and brake to slow down then it starts to pulse. oh this is all on an H22a. I have no clue what else to check.
pulsating idle
http://www.cb7tuner.com/vbb/showthre...29)%20%20%20k5
Here is the tutorial I used. I hope maybe this could help out more. If not I'm sorry.
Check your coolant level
Originally posted by solito_yo View Postok ladies and gents, I have this pulsating idle it pulses between 1000 and 1500. I thought it was an exhaust leak. nope. fitv was deleted. I put a new tps, new iacv, last year from az. it went away when I deleted fitv but then it came back took the IM apart and resealed. it starts fine, but then I drive around push the clutch in and brake to slow down then it starts to pulse. oh this is all on an H22a. I have no clue what else to check.
ok this is an update I cleaned out my IVAC and EGR. and spayed carb cleaner on all vac. lines and manifold, tb, and even seafoamed the system by vac induction and in the fuel. And the problem is still there with erratic idle( surging idle, pulsating idle). I need some serious help. Or more info on this.
Originally posted by oyajicool View PostCoolant level may appear normal/full at the filler neck, but the system may have air in it. Which may cause idle speed surge issue. So, make sure that here's no air in the system by opening the bleed valve while the engine is cool.
i ask because i also have "bouncing" idle. i followed all steps to check for cause. even took apart the intake manifold and hand cleaned it pretty good.
im out of ideas..
