Bleed the brakes
    Bleed the brakes
    I have been experiencing some problems with my breaks and as a result I need to bleed my breaks, now is there any videos I could watch or could someone tell me how or where to find how to do it, I imagine its not to difficult
    thanks
    Trevor
    thanks
    Trevor
    Well the first thing you have to have is the right set of tools. You should get like a bleeder kit or make your own by a see through vacuum line long enough so that the cup reaches the ground.
    Then connect the line to the bleeder valve nipple. Then use the wrench and let someone press the brakes and bleed the system but make sure you add fluid since the reservoir will drain itself never let it get too low or you'll have to bleed the system again.
    When you see no bubbles and a clear stream of fluid in the line your good then close up the valve and remove the line and go to the next valve to bleed. BTW make sure there is fluid in the cup while your bleeding the system so that it travels one way instead of sucking up more air making it time consuming.
      or you can buy these and swap them in then you can bleed your brakes/flush system in about 10mins by yourself.
        ty!!!
