Will this work on our EGR system?
    I know the procedure for drilling out the plugs, and cleaning out the EGR ports and all that on our cars, but, would Scotty's method work on our cars? This seems much easier!
    ALSO, couldn't get the embedded video to work, So...link.
    I hate that guy, super annoying. In short, no. The EGR passages loop around the manifold and there is a TON of gooey, sticky, nastiness in the ports, I seriously doubt you could just "push" it all the way out of the ports.
      Method wont work to our cars for sure.
      私はフィリピン人
        along with that, where would all that shit be pushed to? Itd probably clog up and cause more issues rotor rootering it.
        OP: solvents and compressed air and any other method mentioned in the ton of posts on here will be your tried and true best bet.
          You might be able to get the side port and do that but you wont get to the ports, but just open her up. It doesnt take that long.
          Retro!
          Hater
            His corvette's smoking.
            02 Crv
              i would just get a block off plate if your having problems with the egr valve. i was having problems with mine so just took it off and put the password jdm one on only 20 dollars and looks way better and problem fixed.
                this method doesn't fix cars that actually have to pass nox readings but thank you for your budget suggestion.
