How can I set my Clutch Pedal up
    My Old mechanic set up my clutch pedal and its really pissing me off... its not stiff and normal all the way when I press the clutch. Currently if you were to push it? it will be soft and then after its half way pushed, its normal and hard. Problems are that sometimes it gets me miss shifting. When i got my car back in the day it used to be fine. I NEED to setup my clutch pedal properly!!!!
    The stupid thing is that my old mechanic said " oh... I set it up so the car doesn't jerk that much. ". I was like ...wtf and I seriously never went back to his place.
    I heard it was a bolt that needs to be adjusted... and i wasn't too sure if that's right or wrong but someone told me about it, and they said it was a soft and easy shizz to do.
    Pleaseeeee Help Guys
    Depends on how he "set it up", you could need to bleed the system, or adjust the rod on the master cylinder.
      The bolt doesn't come out of adjustment. Usually, you never need to adjust the pedal. Chances are your hydraulics are failing. Replace both the master and slave cylinders, and properly bleed the system (that can be a serious pain in the ass to do...)
