Water Leak from BFE!!!
    hey all! so im having an issue with my cooling system....i have checked and replaced upper, lower, and a little L shaped hose (underneath the car on the back of the block and under the throttle body) not 100% sure what to call it, but there is still a leak and its impossible to see where its coming from...
    the only clue i can give to you is the "L" hose that i replaced, its trickling down from the "metal pipe" that the "L" hose connects to (btw the "L" hose is only about 4inches.) and i cannot figure how to get to this pipe without pulling the engine. any suggestions or know what i am talking about!?
    Ummm pictures would be beneficial.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      since your talking about that general area, there are some control valves around that area that tend to rust out with age plus the fact that lots of people just throw water in the radiator..anyways the things with small hoses running to them carrying water, are usually leaking themselves.
        Is that the one on the firewall?
        Its the heater core. Should be able to get it from the passenger side with the intake removed. CUT it off don't pull it. It's prob rusted on.
        Is that the hose your talking about?
        steve
          Can you point it out?
            its the pipe that heater hose 14 connects to...above 14 and 8
              oh. Thats the metal pipe. You will prob have to remove the intake. Maybe you can get to it from the bottom.
              Good luck.
              Prob going to have to get that from a JY.
              steve
                I've never changed out the water pipe but I have envisioned that you could remove the thermostat housing and wiggle/slide it out towards the passenger side. Also, hoses 13 and 14 connect to your oil cooler, that's what that thing is that the oil filter seats to.
                  Is it leaking where it meets the block or where it meets the thermostat housing? Or from hose 17?
                  Good luck.
                  steve
                  Why would he need to replace the pipe? More than likely it's a bad o ring.
                    no its from the other side of the pipe not from hose 17
