Transmission Choice
    Transmission Choice
    Alright so with this F22a1 motor I'm putting in my Prelude I was curious as to what I can do for better fuel economy. My H23a1 was only netting me about 25 mpg but I see on here a few guys talking about getting 30-33 mpg with there F22 motors. Now I used an 11 pound flywheel and OEM Exedy replacement clutch and H23 trans(forget exact trans code) Now should that have a significant effect on mpg or should I be alright?
    And for those wondering why I would bother with such a primitive question my 4th gear is slowly getting worse and I will be needing a replacement eventually and wondering if I should get a longer gear Accord trans or if the Prelude's shorter gears should suffice.
    If fuel economy is your priority, then shop around for an F22A trans. You should be able to get in the 30s with the H2A5,H2U4, and H2U5 transmissions. However keep in mind the gearing is much longer so from a performance aspect you will lost some acceleration performance; but not too much since these transmissions are designed for the F22As powerband.
    '94 JDM H22A: 178whp 146wtq
      Alright I appreciate that info. Thank ya
        The lightweight flywheel may end up decreasing fuel economy, rather than increasing it.
        If you do a lot of highway driving, you can have a hybrid transmission built. Shorter H gears for performance, and the longer F 5th gear for highway economy. A few people have done it.
          Why would the flywheel decrease the fuel economy? Never heard that one before.
