Looking for someone that can help me. my trans wont take 3rd it spits it right out can some one help.Thanx
3rd gear wont go in spits it out
I thought I disabled polls for noobs. That poll doesn't even make sense. You're unable to spell the word "what", and you think someone will expect you to be capable of understanding instructions on fixing your transmission? Good luck.
Check your shift linkage, and change your fluid (Honda MTF or GM Synchromesh are my suggestions.) If that doesn't fix it, take it to a shop.
Your synchros are shot.
To avoid replacement of the trans, use GM Synchromesh to pull some extra life out of your trans. It prevents quick shifts making life easier for your synchros so try to rev match as much as possible.
If you dont mind dropping your trans, now is a great time to install some Synchrotech carbon coated synchro rings. A good trans shop shouldnt charge much to do this, and it only takes an hour and a half if you bring your transmission to them and install it yourself. The most expensive part of this is dropping the tranny and installing it. If you can do that, i suggest get the carbon rings and get a badass tranny back Would also be a good time to upgrade to a stage2 clutch and lightented flywheel and if money is there, a short shifter that way everything in the way of shifting is taken care of
Good luck!
Good luck!
Get a new tranny from a junk yard. should be able to find one for 200 bucks.
or get the sychros and have a shop replace them, but its gonna be cheaper to just find a used tranny.
any your poll is dumb and should have never been created in the first place.
member ride thread
DIVULGE MOTORSPORTS
