Steering Vibration
    This might be a rare case but I had a CV axle that was stuck or seized at the CV joint, because the joint inside was not moving when driving at speed it felt like I blew a tire. The steering wheel shook insanely bad, so bad that I got off the highway and took the streets home.
    1993 Accord LX Coupe 5spd
      Thanks a lot guys!
      私はフィリピン人
        Different amount if air in the front tires will also cause steering vibrations.
        10th Anniversary Accord.
        05 Audi A4 Ultra Sport 6MT.
          Your absolutely correct, always I see to it that all my tires have the same psi pressure, say every 2 days.
          私はフィリピン人
            I should start checking them every two days instead of every 4 days
              I recently replaced my torque strut mount because it broke obv and it turnt out to also dramatically help with the vibrations
                Thanks for sharing my man.
                私はフィリピン人
                  Did you figure out the exact cause?
                    Not yet man, I've been too busy with my job, soon i will post the cause after fixing. thanks for asking.
                    私はフィリピン人
                      Is it when you are braking at all? Warped rotors if so. Happens to me.
                        It is when i hit 100 kph i could feel it, but maybe you have a point.
                        私はフィリピン人
                          Hey guys...thank you to your ideas and mechanical wizards, i already solved the problem, after replacing my lower and upper control arm bushing, it was coming from the break rotor and sway bar bushing, i am so pleased to this forum it's very helpful. many thanks to deevergote!
                          私はフィリピン人
                            My steering is so bad I can feel the wheel just pull to one side pulsing even at 5 mph and it just started doing it this week. I also have to check all this stuff. Wish me luck!
                              Wish you luck bro.
                              私はフィリピン人
