smoking throttle cable
    Originally posted by lovef22s View Post
    First! I check the last thread that whose made about this,and it help a bit. Now! my throttle cable is still getting hot, i checked the ground that goes to the battery and it whose corroded, so I Coleen it and reinstall it still the same. Now! My question is there another ground wire that I need to check? and were is it ?
    Who's Coleen? Your throttle cable should not get hot. Ever. It's not a powered cable. It just pulls on the throttle rotor to open the throttle plate.
    You have major grounds on the fender, starter, thermostat housing if memory serves correctly.
